Date/Time: Thu, 25 Apr 2024 10:35:34 +0000
md5 for file does not match: user contributed studies 64 dll
View Count: 844
[2020-01-20 21:16:08] |
User48838 - Posts: 112 |
Any solutions to this issue?
[2020-01-20 21:31:46] |
Do you see this error from the Sierra Chart installer?
[2020-01-20 22:41:51] |
yes
[2020-01-21 10:29:21] |
We recommend trying running the installer again.
[2020-01-21 15:42:08] |
TY that suggestion worked, I had tried that obviously. I have a new issue tho, my Default Spreadsheets for Trading have lost all the math i added to them. Any ideas where i can retrieve them from, I dont see them in Backups. Should I start a new ticket for this issue? |
[2020-01-21 15:57:38] |
Actually I did find the .scss file in backup using the *.* option, when I opened it up it did not appear in the spreadsheet i had open. Where do you suppose it opened? |
[2020-01-23 22:11:02] |
Sierra_Chart Engineering - Posts: 14076 |
We are not understanding the question.
