Date/Time: Sat, 20 Apr 2024 06:59:23 +0000
ASCIL reload everytime sierra
View Count: 552
[2020-01-20 15:27:19] |
stephane1 - Posts: 109 |
Hi I build .dll with microsoft sudio2019 but I have to restart the software Sierra every time when I modify the file. This is not very practical. Is there a procedure? regards SR |
[2020-01-21 10:42:40] |
Refer to the following: Advanced Custom Study Interface and Language (ACSIL): Modifying Advanced Custom Study Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-24 08:49:52] |
thanks you ... fix it...but how can I configure hotkets keybord (Analysis >> Build Custom Studies DLL >> Build >> Release All DLLs and Deny Load or Release Single DLL and Deny Load) ... for work quickly regards SR |
[2020-01-24 09:39:24] |
This can be done through the Keyboard Shortcuts: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
