Date/Time: Sat, 19 Apr 2025 15:21:53 +0000
[User Discussion] - How do I add a mid-point marker to my Volume @ Price profiles?
View Count: 555
[2020-01-20 14:49:03]
mtomas - Posts: 21
i am using Volume at Price profile, i want to add a mark or a line at the midpoint for each profile, how can i accomplish this?
thanks
[2025-03-13 18:34:56]
TopGunTrader - Posts: 191
Just searched for this myself.
[2025-03-13 20:02:28]
John - SC Support - Posts: 39362
We do not think we have anything that does this, but we want to make sure we are understanding the question.
If you want a marker for each bar that shows the mid-point (volume / 2) of that bar, or if you are wanting the midpoint of the overall volume of the profile, then these do not currently exist in the Volume by Price study.
The one thing that is possible, but not what we think you are asking, is to color the bars based on the percentage of the Point of Control, so you could highlight the bar that is approximately 50% of the Point of Control. Refer to the following for this:
Volume By Price Study: Number of POC Ranges to Color
[2025-03-13 23:08:53]
User719512 - Posts: 309
A possible, and non-optimal, solution till 2 SGs for the VbP High/Low are added could be:
Duplicate your VbP study.
Set the Value area to 100.
Hide it.
Use a Spreadsheet Formula to make the mid
=(id1.sg3 + id1.sg4) / 2
Assuming this is what you wanted and that I am understanding your question correctly, the Mid Price of the VbP.
