Date/Time: Tue, 23 Apr 2024 22:47:48 +0000
Correct symbol
View Count: 776
[2020-01-20 14:43:16] |
User231138 - Posts: 3 |
I just started the trial account. intending to trade s&p emini. Data feed appears as SC. What is the correct symbol for s&p emini mar expiry? |
[2020-01-22 23:28:07] |
It is ESH20 The symbols are listed in File >> Find Symbol >> Futures -CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
