Date/Time: Fri, 26 Apr 2024 13:54:28 +0000
How to get last position order
View Count: 488
[2020-01-20 04:48:00] |
User348013 - Posts: 2 |
I would like to know if there is a study or any method to call the last order for my spreadsheet trading. For example, if the position open at a buy , there will be no buy order will open in the future even after the buy position is closed and the buy signal remains true. The next order will be only a sell. |
[2020-01-20 05:11:22] |
Have a look at these two fields in the I column on the Sheet: Daily Num Long Trades (read-only): Daily Num Short Trades (read-only): Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
