Date/Time: Thu, 18 Apr 2024 18:38:50 +0000
Trading System Based on Alert Condition / How to change Quantity?
View Count: 491
[2020-01-19 16:05:43] |
Erwin Ide - Posts: 7 |
Team: I have done everything indicated in the following links: Automated Trading Management Auto Trade System Back Testing but I cannot change the quantity, I am using "Attach Trade Window to Chart" equal to 100. Today only the backtest works with the quantity is equal to 1 and it is very small when working with XBTUSD-BMEX. can you help me or indicate how to have support, BR Erwin Ide |
[2020-01-20 05:25:38] |
The quantity is set through the Trade Window for the chart. Make sure you are setting it on the correct Trade Window: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM (Trade Window Settings Not Applying to Chart or Trading DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-20 05:26:12
