Date/Time: Wed, 18 Nov 2026 12:57:58 +0000
Save Chart instead of chartbook
View Count: 3895
| [2020-01-18 16:47:40] |
| mtomas - Posts: 21 |
new to SC so a little confused. is it possible to save 1 chart as a template? all i see is "save chartbook" is everything a 'chartbook'? i see you can save multiple charts within a chartbook but how about opening a chart as a template based on settings, studies, etc? i just dont see how to save 1 chart... how do i add a specific chart template to an existing chartbook? thanks, i cant find anything on these basic ideas. |
| [2020-01-18 21:08:21] |
For information about Chartbooks, refer to: Chartbooks (Workspaces) Refer to the following for how to use a Chart as a template: Using Chart Templates Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-01-18 22:27:36] |
(please dont not send any links to the help section, i just need the question answered) i saw the section on chartbook already that why i posted a question here to the support desk, because it didnt have my answer is there a way to save a chart? a chart as a template. a standalone chart that does not belong to any chartbook that i can use as a template, and have different chart templates. --- i want a 45 min chart with market profiles and the background as white with bars yellow and purple, with only 7 days loaded with controlbar 3 + 4 active. --- i want another template that is a OHLC with 3day bars with a purple background that has 66 days of data loaded with a 15 period RSI and a MACD with pink lines and previous 3 days pivot with control 1 active. so if i want to see AMZN or GOLD index or 10 year bonds or Bitcoin i can select the template based on the analysis i want to do and just enter the symbol and all my settings, customization's will appear. adding a collection does not change the background color or the timeframe, days loaded or any other settings, it just adds studies... |
| [2020-01-18 23:32:59] |
At this point we are declining further support until such time you have a paid account. You are not paying attention to our documentation and you only have a trial account. Here is the relevant documentation: Using Chart Templates: Duplicating Charts / Template Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-18 23:33:52
