Date/Time: Fri, 29 Mar 2024 11:24:18 +0000
dll acsil
View Count: 824
[2020-01-18 15:08:44] |
stephane1 - Posts: 108 |
Hi I build .dll with microsoft sudio2019 but I have to restart the software Sierra every time when I modify the file. This is not very practical. Is there a procedure? regards SR |
[2020-01-18 18:42:40] |
User907968 - Posts: 800 |
You can use these commands - Pre-build Analysis Menu: Release All DLLs and Deny Load (Build Advanced Custom Studies DLL Window >> Build) Post-build Analysis Menu: Allow Load DLLs (Build Advanced Custom Studies DLL Window >> Build) See here also Advanced Custom Study Interface and Language (ACSIL): Modifying Advanced Custom Study Code |
[2020-01-18 21:08:00] |
The answer given at post #2 is correct.
[2020-01-18 23:15:42] |
bradh - Posts: 846 |
regards You can edit and debug with Visual Studio 2019 and use the Build with Visual C++ On the Sierra Chart Analysis>>Build menu without having to do the DLL unload/reload. |
