Date/Time: Wed, 24 Apr 2024 18:07:36 +0000
Syncing charts between 2 computers
View Count: 902
[2020-01-18 13:10:10] |
user10000 - Posts: 41 |
sorry if i missed this but i was wondering if there was a way to sync saved chartbooks between 2 different desktops. So if i make changes on 1 desktop i wont have repeat it again for another, thanks
[2020-01-18 13:34:04] |
User138602 - Posts: 169 |
just open the changed chartbook in the 2nd instance. You can select the folder you want to access...its the data folder btw. After that "save as" in the 2nd instance.
[2020-01-20 05:23:40] |
The only way to do something like this is to send the Chartbook to yourself and then delete it on the instance of Sierra Chart you want it updated and then it will be downloaded next time you restart Sierra Chart. Refer to: File Sharing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
