Date/Time: Fri, 29 Mar 2024 08:35:20 +0000
Connect Data
View Count: 467
[2020-01-18 10:37:09] |
User901605 - Posts: 2 |
Reading Internal Order ID file. | 2020-01-17 23:42:01.152 Reading Trade Orders file. | 2020-01-17 23:42:01.357 Reading Trade Positions file. | 2020-01-17 23:42:01.358 Reading Account Balance file. | 2020-01-17 23:42:01.359 UDPListener (1420). Port 22903 | Listening on UDP port 22903. | 2020-01-17 23:42:01.398 Software version: 2036 64-bit | 2020-01-17 23:42:01.399 Usage end date: 2021-01-23 | 2020-01-17 23:42:01.399 Enabled for: Advanced Features 2. | 2020-01-17 23:42:01.399 Enabled for: Sierra Chart Historical Data Service. | 2020-01-17 23:42:01.399 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-01-17 23:42:01.399 Allow Support for Sierra Chart Data Feeds is disabled. | 2020-01-17 23:42:01.399 Current selected Data/Trading service: GAIN Capital/OEC | 2020-01-17 23:42:01.399 Custom symbol settings values: disabled | 2020-01-17 23:42:01.399 Chart Update Interval: 500 | 2020-01-17 23:42:01.399 Intraday Data Storage Time Unit: 0 | 2020-01-17 23:42:01.399 Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2020-01-17 23:42:01.399 2020-01-17 23:42:01 Local computer time | 2020-01-17 23:42:01.399 2020-01-17 22:42:01 Local computer time in UTC | 2020-01-17 23:42:01.399 2020-01-17 23:42:01 Local computer time in SC Time Zone | 2020-01-17 23:42:01.399 2020-01-17 22:42:00 Server time in UTC | 2020-01-17 23:42:01.399 Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-01-17 23:42:01.399 Program path: C:\SierraChart\ | 2020-01-17 23:42:01.399 Data Files path: C:\SierraChart\Data\ | 2020-01-17 23:42:01.399 OS Version Number: 10.0 | 2020-01-17 23:42:01.399 Locale Setting: C | 2020-01-17 23:42:01.399 DLLs: fims_vc.dll, fims_volatilni_usecka.dll, Source.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-01-17 23:42:01.400 Checking for new symbol settings. Requested symbol settings MD5 for service code oec. Request ID: 1. | 2020-01-17 23:42:01.430 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-01-17 23:42:01.470 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-01-17 23:42:01.501 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-01-17 23:42:01.501 Received 5 login tokens. | 2020-01-17 23:42:01.615 Symbol settings MD5 received. Request ID: 1. | 2020-01-17 23:42:01.739 Symbol settings are up-to-date for oec. | 2020-01-17 23:42:01.739 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:42:06.609 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:42:06.649 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:42:06.649 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:42:06.782 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:42:06.978 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:42:07.378 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:42:07.378 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:42:07.378 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:42:07.378 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:07.378 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:42:07.379 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:42:07.379 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:42:07.379 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:42:07.379 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:42:07.379 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:07.379 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:42:10.386 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:42:10.394 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:42:10.394 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:42:10.523 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:42:10.709 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:42:11.112 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:42:11.113 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:42:11.113 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:42:11.113 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:42:11.113 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:11.113 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:42:11.113 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:42:11.113 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:42:11.134 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:42:11.134 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:11.134 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:42:14.153 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:42:14.155 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:42:14.155 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:42:14.284 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:42:14.484 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:42:14.891 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:42:14.891 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:42:14.891 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:42:14.892 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:42:14.892 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:14.892 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:42:14.892 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:42:14.892 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:42:14.901 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:42:14.901 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:14.901 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:42:17.911 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:42:17.912 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:42:17.912 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:42:18.044 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:42:18.243 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:42:18.653 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:42:18.653 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:42:18.653 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:42:18.653 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:18.653 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:42:18.653 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:42:18.654 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:42:18.654 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:42:18.667 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:42:18.667 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:18.667 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:42:21.679 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:42:21.681 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:42:21.681 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:42:21.811 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:42:22.010 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:42:22.420 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:42:22.421 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:42:22.421 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:42:22.421 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:42:22.422 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:22.422 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:42:22.422 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:42:22.422 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:42:22.427 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:42:22.427 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:22.427 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:42:25.421 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:42:25.422 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:42:25.423 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:42:25.555 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:42:25.753 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:42:26.172 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:42:26.174 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:42:26.175 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:42:26.175 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:42:26.175 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:26.175 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:42:26.175 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:42:26.175 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:42:26.192 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:42:26.192 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:26.192 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:42:29.180 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:42:29.181 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:42:29.182 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:42:29.307 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:42:29.503 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:42:29.901 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:42:29.901 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:42:29.901 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:42:29.902 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:42:29.902 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:29.902 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:42:29.902 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:42:29.902 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:42:29.904 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:42:29.904 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:29.904 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:42:32.921 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:42:32.922 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:42:32.922 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:42:33.050 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:42:33.273 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:42:33.665 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:42:33.665 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:42:33.665 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:42:33.665 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:33.665 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:42:33.665 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:42:33.666 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:42:33.666 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:42:33.679 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:42:33.679 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:33.679 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:42:36.689 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:42:36.731 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:42:36.732 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:42:36.852 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:42:37.044 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:42:37.436 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:42:37.437 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:42:37.437 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:42:37.437 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:42:37.437 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:42:37.437 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:37.438 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:42:37.438 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:42:37.445 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:42:37.445 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:37.445 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:42:40.470 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:42:40.472 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:42:40.472 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:42:40.607 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:42:40.818 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:42:41.205 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:42:41.206 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:42:41.206 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:42:41.206 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:41.206 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:42:41.206 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:42:41.206 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:42:41.206 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:42:41.219 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:42:41.219 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:41.219 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:42:44.229 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:42:44.231 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:42:44.231 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:42:44.351 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:42:44.568 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:42:44.952 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:42:44.953 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:42:44.953 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:42:44.953 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:42:44.953 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:44.953 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:42:44.954 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:42:44.954 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:42:44.969 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:42:44.969 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:44.969 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:42:47.964 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:42:47.965 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:42:47.966 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:42:48.112 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:42:48.311 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:42:48.700 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:42:48.701 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:42:48.701 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:42:48.701 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:42:48.701 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:42:48.701 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:48.701 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:42:48.701 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:42:48.712 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:42:48.712 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:48.712 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:42:51.723 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:42:51.724 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:42:51.725 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:42:51.950 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:42:52.139 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:42:52.716 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:42:52.716 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:42:52.716 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:42:52.717 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:42:52.717 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:52.717 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:42:52.717 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:42:52.717 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:42:52.726 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:42:52.726 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:52.726 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:42:55.736 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:42:55.737 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:42:55.738 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:42:55.926 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:42:56.121 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:42:56.645 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:42:56.646 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:42:56.646 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:42:56.646 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:42:56.647 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:42:56.647 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:56.647 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:42:56.647 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:42:56.654 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:42:56.654 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:42:56.654 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:42:59.648 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:42:59.650 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:42:59.650 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:42:59.773 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:42:59.965 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:00.441 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:00.442 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:00.442 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:00.442 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:00.442 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:00.442 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:00.442 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:00.442 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:00.451 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:00.451 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:00.451 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:03.460 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:03.462 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:43:03.462 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:03.586 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:43:03.777 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:04.342 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:04.342 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:04.342 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:04.342 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:04.342 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:04.342 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:04.343 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:04.343 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:04.348 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:04.348 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:04.348 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:07.358 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:07.403 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:43:07.403 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:07.526 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:43:07.729 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:08.113 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:08.114 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:08.114 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:08.114 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:08.114 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:08.114 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:08.114 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:08.115 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:08.129 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:08.129 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:08.129 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:11.118 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:11.119 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:43:11.120 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:11.246 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:43:11.440 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:11.826 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:11.826 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:11.826 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:11.826 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:11.826 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:11.826 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:11.826 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:11.826 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:11.841 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:11.841 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:11.841 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:14.852 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:14.853 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:43:14.854 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:14.981 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:43:15.168 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:15.565 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:15.565 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:15.565 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:15.566 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:15.566 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:15.566 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:15.566 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:15.566 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:15.570 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:15.570 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:15.570 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:18.579 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:18.581 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:43:18.581 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:18.706 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:43:18.911 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:19.292 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:19.293 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:19.293 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:19.293 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:19.293 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:19.293 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:19.293 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:19.293 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:19.297 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:19.297 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:19.297 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:22.314 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:22.314 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:43:22.315 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:22.436 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:43:22.644 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:23.024 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:23.024 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:23.024 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:23.024 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:23.024 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:23.024 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:23.024 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:23.024 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:23.044 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:23.044 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:23.044 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:26.048 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:26.049 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:43:26.049 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:26.173 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:43:26.379 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:26.755 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:26.756 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:26.756 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:26.756 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:26.756 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:26.756 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:26.756 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:26.756 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:26.764 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:26.764 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:26.764 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:29.783 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:29.784 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:43:29.784 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:29.916 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:43:30.128 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:30.529 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:30.529 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:30.529 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:30.529 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:30.529 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:30.529 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:30.529 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:30.529 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:30.544 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:30.544 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:30.545 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:33.556 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:33.557 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:43:33.558 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:33.689 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:43:33.899 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:34.298 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:34.298 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:34.298 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:34.298 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:34.298 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:34.298 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:34.298 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:34.298 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:34.304 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:34.304 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:34.304 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:37.323 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:37.353 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:43:37.354 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:37.475 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:43:37.687 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:38.070 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:38.071 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:38.071 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:38.071 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:38.071 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:38.071 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:38.071 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:38.071 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:38.092 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:38.093 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:38.093 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:41.098 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:41.141 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:43:41.142 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:41.267 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:43:41.461 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:41.861 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:41.861 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:41.861 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:41.861 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:41.861 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:41.861 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:41.861 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:41.861 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:41.862 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:41.862 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:41.862 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:44.856 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:44.857 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:43:44.858 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:44.987 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:43:45.196 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:45.597 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:45.598 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:45.598 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:45.598 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:45.598 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:45.599 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:45.599 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:45.599 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:45.611 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:45.612 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:45.612 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:48.606 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:48.608 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:43:48.608 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:48.737 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:43:48.923 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:49.330 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:49.330 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:49.330 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:49.331 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:49.331 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:49.331 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:49.331 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:49.331 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:49.340 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:49.340 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:49.340 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:52.351 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:52.352 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:43:52.353 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:52.485 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:43:52.682 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:53.091 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:53.091 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:53.091 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:53.092 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:53.092 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:53.092 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:53.092 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:53.092 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:53.099 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:53.099 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:53.099 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:56.087 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:56.089 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:43:56.090 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:56.222 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:43:56.420 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:43:56.831 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:43:56.832 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:43:56.832 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:43:56.832 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:43:56.833 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:43:56.833 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:56.833 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:43:56.833 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:43:56.839 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:43:56.840 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:43:56.840 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:43:59.844 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:43:59.848 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:43:59.848 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:43:59.973 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:00.168 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:00.557 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:00.557 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:00.557 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:00.557 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:00.557 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:00.557 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:00.557 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:00.557 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:00.578 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:00.578 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:00.578 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:44:03.574 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:44:03.574 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:44:03.574 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:44:03.726 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:03.919 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:04.312 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:04.312 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:04.312 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:04.313 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:04.313 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:04.313 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:04.313 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:04.313 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:04.324 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:04.324 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:04.324 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:44:07.327 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:44:07.329 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:44:07.329 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:44:07.456 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:07.650 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:08.050 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:08.051 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:08.051 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:08.051 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:08.051 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:08.051 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:08.051 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:08.051 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:08.060 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:08.060 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:08.061 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:44:11.065 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:44:11.114 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:44:11.114 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:44:11.247 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:11.448 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:11.840 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:11.841 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:11.841 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:11.841 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:11.841 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:11.841 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:11.841 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:11.841 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:11.850 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:11.850 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:11.850 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:44:14.852 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:44:14.854 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:44:14.855 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:44:15.039 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:15.236 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:15.689 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:15.689 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:15.689 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:15.690 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:15.690 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:15.690 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:15.690 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:15.690 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:15.699 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:15.700 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:15.700 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:44:18.694 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:44:18.696 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:44:18.696 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:44:18.820 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:19.009 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:19.470 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:19.470 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:19.470 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:19.470 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:19.470 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:19.471 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:19.471 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:19.471 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:19.484 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:19.484 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:19.485 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:44:22.478 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:44:22.479 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:44:22.480 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:44:22.606 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:22.810 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:23.288 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:23.288 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:23.288 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:23.289 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:23.289 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:23.289 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:23.289 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:23.289 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:23.297 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:23.297 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:23.298 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:44:26.291 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:44:26.293 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:44:26.294 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:44:26.417 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:26.617 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:27.096 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:27.097 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:27.097 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:27.097 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:27.097 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:27.097 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:27.097 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:27.097 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:27.107 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:27.107 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:27.107 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:44:30.113 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:44:30.115 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:44:30.115 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:44:30.237 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:30.437 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:31.012 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:31.013 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:31.013 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:31.013 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:31.013 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:31.013 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:31.013 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:31.013 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:31.023 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:31.024 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:31.024 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:44:34.026 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:44:34.028 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:44:34.029 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:44:34.169 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:34.354 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:34.862 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:34.862 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:34.862 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:34.863 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:34.863 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:34.863 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:34.863 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:34.863 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:34.870 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:34.870 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:34.870 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:44:37.865 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:44:37.867 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:44:37.868 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:44:37.985 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:38.185 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:38.565 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:38.566 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:38.566 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:38.566 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:38.566 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:38.566 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:38.566 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:38.566 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:38.572 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:38.572 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:38.572 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:44:41.575 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:44:41.649 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:44:41.649 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:44:41.777 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:41.983 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:42.467 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:42.467 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:42.467 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:42.467 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:42.468 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:42.468 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:42.468 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:42.468 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:42.478 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:42.478 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:42.479 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:44:45.478 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:44:45.483 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:44:45.495 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:44:45.626 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:45.822 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:46.234 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:46.235 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:46.235 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:46.235 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:46.235 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:46.235 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:46.235 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:46.235 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:46.246 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:46.246 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:46.246 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:44:49.241 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:44:49.242 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:44:49.242 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:44:49.370 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:49.573 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:49.976 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:49.977 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:49.977 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:49.977 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:49.977 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:49.977 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:49.977 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:49.977 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:50.001 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:50.002 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:50.003 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:44:52.996 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:44:52.999 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:44:52.999 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:44:53.131 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:53.336 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:53.741 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:53.741 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:53.741 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:53.741 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:53.741 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:53.742 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:53.742 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:53.742 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:53.750 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:53.751 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:53.751 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:44:56.748 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:44:56.750 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:44:56.750 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:44:56.875 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:44:57.072 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:44:57.466 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:44:57.466 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:44:57.466 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:44:57.467 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:44:57.467 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:57.467 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:44:57.467 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:44:57.467 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:44:57.477 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:44:57.477 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:44:57.477 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:45:00.478 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:45:00.480 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:45:00.480 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:45:00.610 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:45:00.811 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:45:01.218 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:45:01.218 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:45:01.218 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:45:01.218 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:45:01.218 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:45:01.218 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:45:01.219 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:45:01.219 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:45:01.227 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:45:01.227 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:45:01.227 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:45:04.228 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:45:04.229 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:45:04.230 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:45:04.364 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:45:04.559 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:45:04.968 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:45:04.968 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:45:04.968 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:45:04.969 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:45:04.969 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:45:04.969 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:45:04.969 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:45:04.969 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:45:04.981 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:45:04.981 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:45:04.981 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:45:07.984 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:45:07.986 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:45:07.986 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:45:08.114 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:45:08.304 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:45:08.706 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:45:08.707 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:45:08.707 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:45:08.707 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:45:08.707 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:45:08.707 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:45:08.707 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:45:08.707 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:45:08.712 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:45:08.712 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:45:08.712 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:45:11.717 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:45:11.760 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:45:11.761 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:45:11.880 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:45:12.077 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:45:12.466 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:45:12.466 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:45:12.466 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:45:12.466 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:45:12.466 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:45:12.466 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:45:12.466 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:45:12.466 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:45:12.477 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:45:12.477 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:45:12.477 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:47:12.479 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:47:12.522 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:47:12.523 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:47:12.652 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:47:12.865 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:47:13.274 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:47:13.275 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:47:13.275 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:47:13.275 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:47:13.275 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:47:13.276 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:47:13.276 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:47:13.276 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:47:13.295 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:47:13.296 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:47:13.296 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:49:13.307 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:49:13.350 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:49:13.350 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:49:13.474 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:49:13.671 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:49:14.058 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:49:14.058 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:49:14.058 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:49:14.058 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:49:14.059 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:49:14.059 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:49:14.059 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:49:14.059 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:49:14.069 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:49:14.069 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:49:14.069 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:51:14.073 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:51:14.114 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:51:14.115 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:51:14.245 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:51:14.454 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:51:14.871 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:51:14.872 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:51:14.872 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:51:14.872 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:51:14.873 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:51:14.873 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:51:14.873 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:51:14.873 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:51:14.887 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:51:14.887 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:51:14.887 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:53:14.889 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:53:14.932 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:53:14.933 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:53:15.057 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:53:15.253 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:53:15.815 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:53:15.815 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:53:15.815 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:53:15.816 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:53:15.816 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:53:15.816 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:53:15.816 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:53:15.816 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:53:15.824 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:53:15.825 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:53:15.825 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:55:15.827 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:55:15.870 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:55:15.871 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:55:15.993 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:55:16.196 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:55:16.592 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:55:16.593 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:55:16.593 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:55:16.593 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:55:16.593 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:55:16.593 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:55:16.593 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:55:16.593 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:55:16.597 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:55:16.597 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:55:16.597 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:57:16.590 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:57:16.644 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-17 23:57:16.644 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:57:16.776 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:57:16.975 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:57:17.383 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:57:17.384 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:57:17.384 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:57:17.384 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:57:17.384 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:57:17.384 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:57:17.384 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:57:17.385 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:57:17.392 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:57:17.392 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:57:17.392 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-17 23:59:17.412 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-17 23:59:17.456 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-17 23:59:17.456 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-17 23:59:17.590 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-17 23:59:17.781 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-17 23:59:18.272 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-17 23:59:18.273 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-17 23:59:18.273 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-17 23:59:18.273 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-17 23:59:18.273 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-17 23:59:18.273 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:59:18.274 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-17 23:59:18.274 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-17 23:59:18.283 GAIN Capital/OEC | Disconnected. | 2020-01-17 23:59:18.283 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-17 23:59:18.283 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-18 00:01:18.285 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-18 00:01:18.328 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-18 00:01:18.328 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-18 00:01:18.457 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-18 00:01:18.654 GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-01-18 00:01:18.938 * GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-18 00:01:18.938 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-18 00:01:18.938 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-18 00:01:18.938 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-18 00:01:18.938 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-18 00:01:18.938 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-18 00:01:18.938 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-18 00:01:18.938 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-18 00:01:18.938 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-18 00:01:18.955 GAIN Capital/OEC | Disconnected. | 2020-01-18 00:01:18.955 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-18 00:01:18.955 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-18 00:03:18.948 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-18 00:03:18.987 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-18 00:03:18.987 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-18 00:03:19.101 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-18 00:03:19.295 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-18 00:03:19.564 GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-01-18 00:03:19.564 * GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-18 00:03:19.564 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-18 00:03:19.564 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-18 00:03:19.564 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-18 00:03:19.564 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-18 00:03:19.564 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-18 00:03:19.564 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-18 00:03:19.564 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-18 00:03:19.565 GAIN Capital/OEC | Disconnected. | 2020-01-18 00:03:19.565 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-18 00:03:19.565 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-18 00:05:19.565 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-18 00:05:19.607 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-18 00:05:19.607 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-18 00:05:19.738 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-18 00:05:19.928 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-18 00:05:20.220 GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-01-18 00:05:20.221 * GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-18 00:05:20.221 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-18 00:05:20.221 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-18 00:05:20.221 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-18 00:05:20.221 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-18 00:05:20.221 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-18 00:05:20.221 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-18 00:05:20.221 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-18 00:05:20.229 GAIN Capital/OEC | Disconnected. | 2020-01-18 00:05:20.229 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-18 00:05:20.230 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-18 00:07:20.237 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-18 00:07:20.281 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-18 00:07:20.281 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-18 00:07:20.405 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-18 00:07:20.591 GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: Stávající připojení bylo vynuceně ukončeno vzdáleným hostitelem. | 2020-01-18 00:07:20.875 GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-01-18 00:07:20.875 * GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-18 00:07:20.875 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-18 00:07:20.875 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-18 00:07:20.875 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-18 00:07:20.875 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-18 00:07:20.875 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-18 00:07:20.875 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-18 00:07:20.875 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-18 00:07:20.877 GAIN Capital/OEC | Disconnected. | 2020-01-18 00:07:20.877 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-18 00:07:20.877 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-18 00:09:20.872 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-18 00:09:20.912 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-18 00:09:20.913 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-18 00:09:21.030 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-18 00:09:21.242 GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: Stávající připojení bylo vynuceně ukončeno vzdáleným hostitelem. | 2020-01-18 00:09:21.508 GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-01-18 00:09:21.508 * GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-18 00:09:21.509 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-18 00:09:21.509 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-18 00:09:21.509 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-18 00:09:21.509 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-18 00:09:21.509 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-18 00:09:21.509 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-18 00:09:21.509 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-18 00:09:21.512 GAIN Capital/OEC | Disconnected. | 2020-01-18 00:09:21.512 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-18 00:09:21.512 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-18 00:11:21.519 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-18 00:11:21.557 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2020-01-18 00:11:21.558 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-18 00:11:21.686 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-18 00:11:21.881 GAIN Capital FIX Trading socket (1) | Socket send error. Windows error code 10054: Stávající připojení bylo vynuceně ukončeno vzdáleným hostitelem. | 2020-01-18 00:11:22.164 GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-01-18 00:11:22.165 * GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-18 00:11:22.165 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-18 00:11:22.165 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-18 00:11:22.165 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-18 00:11:22.165 GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2020-01-18 00:11:22.165 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-18 00:11:22.165 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-18 00:11:22.167 GAIN Capital/OEC | Disconnected. | 2020-01-18 00:11:22.167 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-18 00:11:22.167 |
[2020-01-18 21:05:40] |
Refer to the following section: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ConnectionProblem This could also be due to the market being closed since Gain Capital does not accept connections when the market is closed. This is explained in the section linked above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
