Date/Time: Sat, 20 Apr 2024 13:47:05 +0000
Tick chart
View Count: 444
[2020-01-17 17:57:51] |
Dennis B. - Posts: 263 |
Put up a your NYSE tick chart, but graphic settings will not work. Can only get a chart with a black back ground. I prefer a white back ground, as far as the ticky numbers they work fine.
[2020-01-17 21:21:54] |
Make sure you are at changing the color in the right Graphics Settings window. This is explained here: Graphics Settings: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
