Date/Time: Thu, 25 Apr 2024 12:19:47 +0000
Symbols
View Count: 519
[2020-01-17 17:45:26] |
Dennis B. - Posts: 263 |
What are the symbols for the delayed quotes/charts for NYSE and SP cash.
[2020-01-17 19:55:20] |
Do you mean delayed data for NYSE stocks and the S&P cash indices? There is no delayed streaming data provided for those. There is only historical data that is delayed by 10-15 minutes which periodically updates. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-17 20:40:47] |
Yeah, that's what I mean...what are the correct symbols for those delayed charts.
[2020-01-18 08:13:34] |
For cash indices, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Cash Indexes For stocks, refer to: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
