Date/Time: Fri, 29 Mar 2024 08:11:26 +0000
Scale problem
View Count: 434
[2020-01-17 16:44:55] |
User275674 - Posts: 1 |
Hi. I have a problem.... When i want to trade CL, the pointer of the crosshair moves each 0.25 ticks, like if it was Nasdaq o E-mini S&P, but CL moves each 0.1 ticks. So when I want to place a limit order I just can put the order at X.00 , X.025 , X.0.50 or X0.75..... but in CL i need to be able to set orders at X.1, X.2, X.3, .... X.9. How can I chage this settings? I think its not problem of de scale, but the pointer settings. Thank you! |
[2020-01-17 17:15:02] |
Select Chart >> Chart Settings. What is the the Tick Size set to?
