Date/Time: Mon, 06 May 2024 02:59:11 +0000
[User Discussion] - Sierra users, how good is your data feed?
View Count: 2758
[2020-01-22 15:44:48] |
JM-JO - Posts: 38 |
Anyone else notice this issue with MDH and Windows 10?
SC chart drawing time with Win 10 is much longer than with Win 7 the update times have doubled or tripled
I observe exactly the same increase as you : between x2 and x3.Afaik Sierra is not using the low setting of 10ms when the update in reality takes more than 10ms. It will get delayed automatically.
I suggest to close all chartbooks and open a new chartbook dedicated for data acquisition, and only open one or two charts, with no study added. The lower the refresh of SC and the better the sync of your PC, the better the results you get.When you minimize SC, the CPU load should be close to 0%. Date Time Of Last Edit: 2020-01-22 19:30:29
[2020-01-22 17:42:50] |
Chad - Posts: 231 |
Hi Elji, here is a new one for CLH20 - I made sure to complete all initial configurations that you listed. Sorry again for the incorrect versions, hopefully this one is sufficient.
Timestamps - CLH20 - TU 1 tick - 2020-01-22.csv - Attached On 2020-01-22 17:42:32 UTC - Size: 1.9 MB - 318 views |
[2020-01-22 19:35:35] |
JM-JO - Posts: 38 |
Chad, same as before. Your data are totally unusable: - your PC clock is ahead by 10min. - your SC refresh is way beyond the 10ms I recommended. |
[2020-01-22 19:47:51] |
Chad - Posts: 231 |
I don't understand why; this latest file was made on a Windows Server 2012 VPS in Chicago, and I went to Internet Time settings from the taskbar then 'Update now' to sync with time.windows.com. I set the SC refresh at 10ms from Global Settings>>General, and made sure the Chart settings were using the global refresh. |
[2020-01-23 06:43:54] |
nosast - Posts: 290 |
Attached is my file logging NQ from Germany with Denali during globex asian session (low vol). 109 ms to 1300 ms OS is Windows 10 and my typical ping to Chicago is around 110 ms. Date Time Of Last Edit: 2020-01-23 13:01:14
Timestamps - NQH20_FUT_CME - TU 1 sec - 2020-01-22.csv - Attached On 2020-01-23 06:43:51 UTC - Size: 570.89 KB - 298 views Attachment Deleted. |
[2020-01-23 11:20:00] |
JM-JO - Posts: 38 |
Thanks nosast, please set the file to "public".
