Date/Time: Sat, 27 Apr 2024 02:35:55 +0000
Login Info
View Count: 467
[2020-01-17 14:08:53] |
User976943 - Posts: 37 |
Hi, How can I know which is my user name and passwword to login without using the Help menu? Thanks |
[2020-01-17 16:08:26] |
The only thing you can do in regards to the password is to set a new one here: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo And then you will know what it is. The username can be seen at the top of each post. It begins with TransAct_User_ Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-17 16:08:41
