Date/Time: Fri, 26 Apr 2024 18:11:05 +0000
Apply moving average to a study
View Count: 510
[2020-01-17 00:18:45] |
mtomas - Posts: 21 |
i am using an indicator with only 1 input, periods... i wanted to apply a MA to this indicator to replace the signal with the MA what study would i use? |
[2020-01-18 16:51:13] |
hi, it seems like a simple response... is there a way to add a MA to an indicator, any indicator? thanks
[2020-01-18 19:26:46] |
John - SC Support - Posts: 31154 |
Yes, you can apply a Moving Average to any indicator that makes sense to have a Moving Average. Just use the Based On setting on the Moving Average window. Refer to the information here: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
