Date/Time: Wed, 24 Apr 2024 10:13:01 +0000
Denali Realtime Data Difference to REALTIME
View Count: 561
[2020-01-16 22:31:16] |
User626251 - Posts: 5 |
Hi i have a difference by my Realtime Connection of Denali and The Local TIME? Now is 15.12 OCLOCK NY TIME and my last bar is by 14.45 NY TIME OClock waht is here the issue ? Thanks |
[2020-01-16 22:44:59] |
Keep in mind the CME is currently closed. This is from 5 PM to 6 PM US Eastern time.
[2020-01-16 22:55:30] |
But this Problem i had to on 9.30 NY TIME , with this diffenrece , with other data feed i had never this issues .....
[2020-01-16 23:00:32] |
http://www.sierrachart.com/image.php?Image=1579215600732.png
Anmerkung 2020-01-16 235713.png / V - Attached On 2020-01-16 22:58:00 UTC - Size: 304.52 KB - 226 views Attachment Deleted. |
[2020-01-16 23:07:17] |
You need to look at the time at the top of the chart to know the latest time. You cannot use the times at the timescale at the bottom of the chart.
[2020-01-16 23:49:16] |
at moment its right ... i dont know waht it was i restart all its okay now .......
