Date/Time: Fri, 29 Mar 2024 01:50:56 +0000
spreasheets
View Count: 556
[2020-01-16 21:53:57] |
arruga - Posts: 249 |
Hi I got a long only spreadsheet system (only the entry buy column has data)... I got attached stop and take profit orders via trade window... it works fine, except some short positions were initiated at times on the back test (on historical daily bars, not replay on intraday). Any idea as to why and how some short positions are being initiated? thanks |
[2020-01-17 18:02:01] |
hello!
[2020-01-17 20:02:08] |
would you mind explaining what is the implication of selecting different simulated account starting balances? it doesn't seem to be causing any impact
[2020-01-18 12:23:15] |
Refer to: Automated Trading Management: Troubleshooting Automated Trading System Behavior An account balance is not used with simulated trading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-18 20:21:03] |
Thanks... I understand, but my question is very gral in nature... how come short positions are initiated from a long only system, where only the buy entry column has data? |
[2020-01-20 20:37:39] |
From our position this is impossible for us to answer for all the reasons given in the section linked to.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-20 20:37:47
[2020-01-21 17:17:24] |
Let me try once more... forget my specific case, this is a question general in nature: is there any circumstance in which a spreadsheet-based trading system could initiate a short position when only the BUY ENTRY column has data? (columns L, M, N are empty!) |
[2020-01-24 00:20:56] |
Sierra_Chart Engineering - Posts: 13616 |
It does not make sense but the way to troubleshoot the problem is to see what is initiating the short position by looking at the Trade Activity Log: Trade Activity Log: Viewing Historical Trade Activity You need to look at the Order Action Field and find out what is the source of that short position and what particular order action column or what. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
