Date/Time: Wed, 24 Apr 2024 22:47:29 +0000
Clearing Trade Simulation Orders/Data
View Count: 1424
[2020-01-16 18:34:58] |
jaxscott1 - Posts: 24 |
When I have 2 Sim accounts, is it possible to clear the data of only 1 account and leave the data of the other intact? Seems like the only option is to obliterate ALL the data across all sim accounts.
[2020-01-16 21:56:02] |
This is supported. Follow the instructions here: Trade Activity Log: Clearing Trade Activity Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-16 22:28:15] |
Ok I see. Is there a way to reset the sim account starting balance to another amount AFTER it was created? I see the option when creating NEW accounts under Gen Settings/Gen Trade Settings, but not where to change after created.
[2020-01-16 23:18:10] |
There is no simulated account balance used. Simulated account balances only exist with these services: Simulated Futures Trading Service The setting you are referring to is not used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
