Date/Time: Fri, 26 Apr 2024 15:47:43 +0000
Study to sum up the symbol value
View Count: 803
[2020-01-16 16:55:20] |
User97684 - Posts: 136 |
Hi, Pls help - which study can i use to add the 'close' of the symbol 1 minute candles ? In my case it is the NYSE TICK, which oscilates between + / - 800 ish. I am looking for a cumulative line . Many thanks, |
Study_to_sum_up_the_Tick_value.png / V - Attached On 2020-01-16 16:55:09 UTC - Size: 63.25 KB - 200 views |
[2020-01-16 17:21:10] |
Use this study: Cumulative Sum of Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
