Date/Time: Fri, 26 Apr 2024 18:59:24 +0000
Add multiple 'study collections' to same price chart?
View Count: 943
[2020-01-16 16:54:58] |
mtomas - Posts: 21 |
hi, i see i can save multiple indicators as a 'collection' then add then as an entire collection to a chart... is it possible to add multiple collections to same chart? currently it only toggles between the one you select thanks |
[2020-01-16 21:31:13] |
Refer to the following for how to save a Study Collection so that it will prompt you as to whether to erase other studies or not: Study Collections: Adding a Study Collection Without Clearing Existing Studies On The Chart (Prompt to Remove Existing Studies) Also, just in case what you were asking was how to select multiple study collections at once, that is not supported. You can only select them one at a time from the Analysis menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-16 21:31:20
[2020-01-18 16:49:55] |
thanks, my question was how to add multiple collections to the same chart and not view 1 at a time. thanks for response
[2020-01-18 21:10:25] |
Yes and the section we linked to does explain how to do that. Once the Study Collection is set to prompt whether to remove the studies, then you just always answer No when applying it so the existing studies remain.
[2020-01-18 22:07:58] |
????? your confusing me. Did you read my request? Yes you can add multiple collections to the same chart or No you cant? just answer the question and stop sending so many links to the help section |
[2020-01-19 12:33:06] |
Yes you definitely can. The documentation we link to is the most comprehensive reference. This is why we link to it. Once again here is the relevant documentation: Study Collections: Adding a Study Collection Without Clearing Existing Studies On The Chart (Prompt to Remove Existing Studies) (Adding a Study Collection Without Clearing Existing Studies On The Chart (Prompt to Remove Existing Studies)) Using this method you are able to apply one or more study Collections to a chart without removing or clearing the existing studies. Each time you apply a new Study Collection, press No when prompted, to not clear the existing studies.
