Date/Time: Sat, 20 Apr 2024 04:56:45 +0000
IQFeed Can't connect.
View Count: 841
[2020-01-16 13:35:33] |
User457601 - Posts: 2 |
Hello, I tried to connect to IQFeed data. Cant connect. IQFeed | Connecting. | 2020-01-16 14:24:42.557 IQFeed | Starting interface software. | 2020-01-16 14:24:42.557 IQFeed | Error starting IQ Feed interface software. RunFileUnderOS returned error. | 2020-01-16 14:24:42.560 * IQFeed | Failed to look up the port number for the Admin connection. Using default port. | 2020-01-16 14:24:42.560 * IQFeed | Connecting to Admin port 9300 | 2020-01-16 14:24:42.560 Socket (1) | Creating socket. | 2020-01-16 14:24:42.560 Socket (1) | Connecting to IP: 127.0.0.1. | 2020-01-16 14:24:42.561 Socket (1) | Connect event error. Windows error code 10061: Spojení odmítnuto. | 2020-01-16 14:24:42.561 * Socket (1) | CloseSocket call. | 2020-01-16 14:24:42.563 IQFeed | Disconnected from Admin port. | 2020-01-16 14:24:42.563 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-16 14:24:42.563 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-16 14:24:42.563 Socket (1) | Closed. | 2020-01-16 14:24:42.563 Socket (0) | CloseSocket call. | 2020-01-16 14:24:42.574 IQFeed | Disconnected. | 2020-01-16 14:24:42.574 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-16 14:24:42.574 IQFeed | Connecting. | 2020-01-16 14:24:45.575 IQFeed | Starting interface software. | 2020-01-16 14:24:45.575 IQFeed | Error starting IQ Feed interface software. RunFileUnderOS returned error. | 2020-01-16 14:24:45.577 * IQFeed | Failed to look up the port number for the Admin connection. Using default port. | 2020-01-16 14:24:45.577 * IQFeed | Connecting to Admin port 9300 | 2020-01-16 14:24:45.577 Socket (1) | Creating socket. | 2020-01-16 14:24:45.577 Socket (1) | Connecting to IP: 127.0.0.1. | 2020-01-16 14:24:45.577 Socket (1) | Connect event error. Windows error code 10061: Spojení odmítnuto. | 2020-01-16 14:24:45.577 * Socket (1) | CloseSocket call. | 2020-01-16 14:24:45.577 IQFeed | Disconnected from Admin port. | 2020-01-16 14:24:45.577 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-16 14:24:45.577 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-16 14:24:45.577 Socket (1) | Closed. | 2020-01-16 14:24:45.577 Socket (0) | CloseSocket call. | 2020-01-16 14:24:45.588 IQFeed | Disconnected. | 2020-01-16 14:24:45.588 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-16 14:24:45.588 File >> Disconnect selected. | 2020-01-16 14:24:48.279 IQFeed | Disconnected. | 2020-01-16 14:24:48.279 |
[2020-01-16 15:52:20] |
You need to first install the IQ Feed software. Instructions: DTN IQ Feed Data Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
