Date/Time: Sat, 27 Apr 2024 00:11:20 +0000
Watch list symbol change does not change trade/quote symbol
View Count: 717
[2020-01-16 13:07:46] |
joshtrader - Posts: 439 |
When a chart's symbol is changed using the Watch List, the Trade/Quote symbol found in the Symbol Settings for that symbol are not applied to the chart. This seems to be the case for any of the following methods of changing the symbol: 1) the "Watch List" custom dropdown button added to a control bar 2) Clicking the symbol in the watch list itself 3) Keyboard shortcut to cycle through the watch list (+/-) |
[2020-01-16 15:26:56] |
We tested this and there is no problem. Make sure this option is enabled: Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
