Date/Time: Thu, 28 Mar 2024 12:50:50 +0000
Line auto copied from source chart to destination chart
View Count: 420
[2020-01-16 08:24:37] |
User238343 - Posts: 20 |
my source chart(1H) lines have an alert (once per bar) when the price breaks the line. when these lines are auto copied to 1 minute chart all these alerts get copied. does that mean it will alert once per every 1 minute bar as well. how can i avoid that?
[2020-01-16 09:08:04] |
The alert condition in copied Chart Drawings are not going to be evaluated. They are only evaluated in the source chart.
