Date/Time: Thu, 28 Mar 2024 12:14:04 +0000
Questions
View Count: 447
[2020-01-15 21:52:30] |
User149226 - Posts: 16 |
I noticed that my service data provided by SC for the CME/20 stocks was deactivated on the 31st of December. Is this because I am a TOS user despite having the 1987 version? Is my version still able to connect to the TOS API if I decide to reactivate my data subscription? If so for how long will I be able to use TOS for? Thanks
[2020-01-15 22:31:39] |
You can activate either of these two data feeds: Sierra Chart Exchange Data Feed Denali Exchange Data Feed You can continue to use that version with TD Ameritrade as long as TD Ameritrade is available. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
