Date/Time: Sat, 05 Sep 2026 22:05:21 +0000
Trading Dom Graphics
View Count: 853
| [2020-01-15 21:18:05] |
| User467311 - Posts: 7 |
I would like to modify the "look" of the trading dom but am having a problem trying to determine which settings I need to change. I can't seem to find a visual reference for this window that specifies what the various elements are named so I can modify the color, fonts, etc... Please advise. I am attaching a jpg of the original TradingDOM that I wish to modify and the target: TradingDOMmod I wish to emulate.
| [2020-01-16 03:00:47] |
| seandunaway - Posts: 398 |
Graphics Settings Honestly, you just have to tediously tinker one by one in the Graphics Settings like we all learned. You might check with user ticinotrader. He makes the most beautiful sc chartbooks I've ever seen. Date Time Of Last Edit: 2020-01-16 03:06:46
| [2020-01-16 06:31:24] |
There is not exactly what you are looking for but refer to this page: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
