Date/Time: Thu, 18 Apr 2024 05:08:23 +0000
Play alert when order filed multiple instances
View Count: 506
[2020-01-15 20:58:19] |
RIFT - Posts: 124 |
I use 1 instance per symbol. When I trade on instance 1, all instances play the "play alert when order filed", so if it is set to 3 symbols, I hear the alert 3 times. The other instances only play the alert sound once. Is it possible that instance 1 also plays the alert only once? Thank you! |
[2020-01-16 06:54:24] |
Refer to the documentation here about this: Global Trade Settings Windows: Play Alert For New Order (Global Settings >> General Trade Settings >> Notifications) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
