Date/Time: Fri, 26 Apr 2024 15:46:09 +0000
Symbol displayed to Chart's hard right edge
View Count: 669
[2020-01-15 20:32:41] |
User14953 - Posts: 184 |
Customize Chart Header How can 'the' or 'another' symbol be displayed on the right hand side of a chart nearer where the price action is, for quick identification when working multiple books, charts, and symbols? Thx |
[2020-01-15 20:42:09] |
You can use the Symbol Display study and set it to display anywhere including over to the right: Symbol Display Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-30 23:56:32] |
Judging by my use of this feature for the countdown timer, consistent placement of that graphic a set distance from the right edge through a variety of chart width adjustments resulted in a variety of distances from the right edge for timer placement. Still haven't caught on how to place the countdown timer 10"millimeters" equivalent from anywhere near the right edge of the chart. When the chart window width is resized, the countdown timer distance from right edge goes bats. Am I doing something wrong? |
[2020-01-31 09:12:48] |
It is hard to say what is the issue unless we can see exactly what you are seeing. Could you provide chart images following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-31 09:13:05
