Date/Time: Fri, 29 Mar 2024 06:34:29 +0000
Timestamp missing on 4-0 reversal bar
View Count: 707
[2020-01-15 19:06:05] |
User502498 - Posts: 33 |
Is there a setting I have wrong here? Most times print, but there are gaps as well. Is it something to do with the bar formation? Image attached. This is a 4-0 reversal bar. Running the latest SC. |
2020-01-15_11-04-30.png / V - Attached On 2020-01-15 19:05:53 UTC - Size: 49.13 KB - 305 views |
[2020-01-15 20:43:16] |
Not sure why this is the case. Provide that chart by following these instructions so we can test: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-22 16:30:50] |
Sorry for the delay, I missed this message. Here is another screenshot and the chartbook.
2020-01-22_08-29-32.png / V - Attached On 2020-01-22 16:30:21 UTC - Size: 133.21 KB - 192 views Chartbook6.Cht - Attached On 2020-01-22 16:30:37 UTC - Size: 121.01 KB - 219 views |
[2020-01-29 14:36:01] |
Hi, any thoughts on this issue? Did the chartbook work ok?
[2020-01-29 17:37:42] |
John - SC Support - Posts: 30444 |
The reason for the gaps is that you are using a Non-Time Based chart (i.e. Renko) and you have the option for Include Seconds on Intraday Time Scale unset, so the gaps are occurring where there would be a repeat of the same time since it is missing seconds. If you want the timestamps to show up, just enable the option in Chart >> Chart Settings >> Advanced Settings 3 >> Include Seconds on Intraday Time Scale. Refer to the documentation for this here: Chart Settings: Include Seconds on Intraday Chart Timescale (Chart >> Chart Settings >> Scale menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
