Date/Time: Fri, 29 Mar 2024 01:03:40 +0000
Setting to move current price on charts to the left
View Count: 908
[2020-01-15 17:19:47] |
bootsy - Posts: 63 |
Hi there, Am assuming it's very simple but I don't know what the correct term is to search under and have looked in chart settings and can't find anything. Am using the Market Depth Historical Graph indicator, and in order to see what current orders are flashing in I need the price bar to be about 4 or 5 bars to the left of the far right hand of the screen, rather than right up against the right hand side of the screen next to the price axis. At the moment I'm having to do it manually every 5 mins which is not ideal. Does anyone know how to change the setting? Hope I've been clea! Regards, Bootsy |
[2020-01-16 06:50:59] |
Refer to the following for options: Working With Charts: Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
