Date/Time: Thu, 28 Mar 2024 22:24:37 +0000
CME Livestock Prices
View Count: 441
[2020-01-15 16:27:18] |
Marmany - Posts: 301 |
No prices today for either LEG20 of HEG20. Please advise. |
[2020-01-15 17:16:38] |
We are checking on this. This is very unusual.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-15 17:16:43
[2020-01-15 17:23:01] |
Yes we do notice this on one server. This is very unusual. What we want you to do for now is reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-15 17:34:44] |
Re-connection solved the issue. Thank you |
