Date/Time: Mon, 25 Nov 2024 01:56:18 +0000
setting up charts
View Count: 1039
[2014-01-02 16:25:19] |
Carol Rutherford - Posts: 66 |
I am getting setup on a laptop. I have downloaded TWS and Sierra Charts and I have a flash drive that I saved my sierra charts from my main computer. How do I get them to load into sierra on my laptop. Haven't found a support board thread with this answer. Also I am in MST but and have my computer clock set to MST. Will my data come in correctly or do I need to switch my computer clock to EST? Thank you for your help. Carol Rutherford |
[2014-01-03 01:24:27] |
This help topic should answer your question: http://www.sierrachart.com/index.php?l=doc/helpdetails15.html Your computer clock settings do sound correct. For further information refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails38.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
