Date/Time: Sat, 19 Sep 2026 05:29:45 +0000
OCO order child order not on Rithmic exchange according to AMP.
View Count: 1597
[2020-01-15 15:33:47]
User532012 - Posts: 10
After some chats with AMP futures they told me to raise a ticket for this issue.
An incident occured this morning where an OCO stop limit order was not filled. Even after moving the limit order to the price it was not filling. A "Flatten and cancell" had to be used to close the trade.
Amp say that there is no record of any other orders with Rithmic after the initial buy limit order was filled. Meaning no oco server side order seem to have been submitted to them.
I have the "use server side OCO orders" box checked in the Sierra "general trade settings".
The trade in question was initially filled at "12:04.05" as per attached log.
In short the stop:limit was on sierra chart but not on the exchange.
Private File
[2020-01-16 06:46:28]
The Trading Activity Log is not consistent with what you are saying. The order mentioned definitively filled.
Here it is:
Fill  2020-01-15 12:04:05.051  MYMH0-CBOT  Rithmic Trading order update (Filled)  86104  34898797  Stop Limit  1  Sell  28903.0000000  28903.0000000  Open  28906.0000000  1  111826  Close  86102    68458:M:3879196TN0004428  28918.0000000  28906.0000000
In any case you really should be using server-side bracket orders and for support for those, switch to this service which is fully supported by AMP:
Sierra Chart / Trading Technologies Futures Order Routing Service
Date Time Of Last Edit: 2020-01-16 06:48:18
[2020-01-16 09:28:38]
I think you misunderstand my comment or the explanation was poor.
Yes the buy limit order was filled. The point was that the stop limit part of this bracket was not filled.
From the link you mention above: "If you want to use server-side OCO and bracket orders, then enable Global Settings >> General Trade Settings >> Use Server-Side OCO Orders and Use Server-side Bracket Orders. The use of server-side OCO and bracket orders is strongly recommended."
Both these checkboxes are ticked on my platform.
In addition to this setting the "Stop-Limit Order Limit Offset" is set to 4 which is the default.
In essence the price went through my stop without taking me out of the market, i then moved the stop to where the current price was and it still did not close the trade.
[2020-01-16 15:44:22]
The order we quoted above is the Stop-Limit Stop Attached Order. And when that order filled, the position quantity went to 0. All of that is in the log you attached.
[2020-01-16 15:54:06]
Apologies it was the order opened at 12:06.23 that is in question.
[2020-01-17 14:42:20]
Hi, i would appreciate if you could look at this 12:06 trade.
When using bracket or oco orders how can we be sure/how do we know that the exchange has what we see on the screen?
[2020-01-17 20:41:49]
Yes we will be getting to this over the weekend.
[2020-01-27 06:07:00]
Sierra_Chart Engineering - Posts: 24890
In regards to post #6, we need you to follow the instructions here:
Trade Activity Log Analysis: Support Assisted Trade Activity Log Analysis
The Status of the orders will be "Open".
Date Time Of Last Edit: 2020-01-27 06:07:23
[2020-01-27 09:17:41]
Symbol: MYMH0-CBOT
Acc: 111826
Date/time: 15-Jan-2020, 12:06.23 UK time
internal order id: 86105 (filled), 86106 (child target deleted by user), 86107 (child stop did not fill)
*86107 trade in question
Description: Trade 86107 did not execute, you can see from the log that i tried to move it onto the current price to see if it would execute, it did not. FYI the "Stop-Limit Order Limit Offset" is set to the default of 4.
Private File
