Date/Time: Thu, 18 Apr 2024 22:34:36 +0000
How to get back Time Date x axis
View Count: 549
[2020-01-15 15:15:35] |
mtomas - Posts: 21 |
when i detached a window and re-attach it. the x axis (time date) axis disappears.. how do i get it back? thanks i noticed if i have scroll unchecked, when i reattach it doesnt show time axis... if i have scroll checked, it always shows the time axis. with so many settings in SC, i was wondering if there is a setting for time axis to always show or this is just a small bug |
[2020-01-15 17:47:03] |
We will check on this.
[2020-01-15 17:59:24] |
We are not able to reproduce this. Do you see the timescale show up if you resize the chart window? Like maximizing and restoring it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-15 17:59:36
[2020-01-16 16:58:55] |
very odd... i cant reproduce it either. i had a chartbook that was acting funny in other ways so i deleted that chartbook and created a new one.. this one doesnt hide the time axis... if i encounter it again, ill reply. thanks for the follow up |
