Date/Time: Fri, 29 Mar 2024 07:53:54 +0000
64 bit upgrade
View Count: 455
[2020-01-15 14:53:21] |
User430472 - Posts: 3 |
Will the new 64 bit software not import *.scid files from the 32 but software?
[2020-01-15 17:37:21] |
No, this is not correct, all files are compatible between both between the 32-bit and 64-bit version.
