Date/Time: Tue, 04 Feb 2025 08:48:05 +0000
Version 2028 shuts down when I try to print landscape
View Count: 765
[2020-01-15 13:06:33] |
User40526 - Posts: 166 |
got a new computer, loaded the latest version 2028 and when I try to print a chart in landscape, Sierra Chart shuts down. this doesn't happen on my old computer running version 2017 and using the same printer. Advice? |
[2020-01-15 17:46:19] |
Not sure what we can do about something like this. Install a PDF printer driver on your system and try printing to a PDF first and see if you still notice an issue.
