Date/Time: Wed, 24 Apr 2024 16:05:26 +0000
SC does not start anymore on MACOS/WINE
View Count: 486
[2020-01-15 12:57:53] |
User877893 - Posts: 14 |
Hi, I run SC with wine on Macos 10.14 and Ubuntu 18.04. The newest SC stable release 2028 works fine on Ubuntu. The stable release 2021 still works fine on Macos, however all newer stable releases crash during startup. I would appreciate, if you have an idea how to fix it - knowing that you nativly support Windows only. thank you for your help in advance. |
[2020-01-15 17:38:41] |
We do not know the reason for the problem.
