Date/Time: Fri, 26 Apr 2024 14:34:12 +0000
[User Discussion] - CDB studies with TICK-SP as maingraph chart issue
View Count: 820
[2020-01-15 12:00:44] |
User964545 - Posts: 8 |
I have noticed in the last week that when I log-on to SC after the NYSE open (say a few hours after the open) that the CDB up/down tick volume study data (with underlying TICK-SP as main graph) is displaying very differently then in past observations. The CDB is displaying what looks like a leading divergent edge IMO where in the past it appeared differently with 'No edge' at all. This is occuring only Historically as when I log-on to SC in Real-time the CDB resumes the 'No edge' depiction again. I have tried to find some setting to make this Historical CDB phenomina 'with edge' print in Real-time but I cant find anything? This CDB depiction 'with edge' is also occuring in the Overnight market in Real-time vs the cash session where it does Not. I made a screen shot of this with simple colored rectangles around the CDB data sections of interest. I will send the screenshot if requested later. Thank you Support.
[2020-01-15 17:29:21] |
No we do not need to see any screenshots. Do not send those. Refer to the section here, it explains why there issues like this: Cumulative Delta Bars - Volume: Using Drawing Tools on Cumulative Delta Bars And you cannot use that study with the market statistics symbols. You must use Cumulative Delta Bars-Volume instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-15 17:29:50
