Date/Time: Thu, 28 Mar 2024 14:19:31 +0000
Opening multiple chartbook groups
View Count: 1019
[2020-01-15 09:51:02] |
ycomp - Posts: 274 |
Would you consider adding a checkbox for not closing the current chartbooks when you open a Chartbook Group? That way you could open multiple chartbook groups. For example, let's say you have a chartbook group for CL and another for ES and another for 6E... let's say you don't want to open CL right now.. so you could easily open the chartbooks for ES and 6E this way. |
[2020-01-15 17:11:09] |
Yes we can do that.
[2020-01-15 17:18:35] |
great
[2020-05-07 15:25:03] |
microcomp - Posts: 21 |
That feature is no longer working on my Green Charts. I have unchecked the box that says "Close Existing Chartbooks When Open Chartbook Group" and still all my Chartbooks are closed whenever I open a new chartbook group. I have tried this in several different versions of Green Charts - 2054 and 2098 and it does not work in either. I think it used to work a week or so ago but something is not working now. Please fix or let me know if my Green Charts has a problem.
[2020-05-08 06:58:41] |
We see why there is a problem with this. The option was never implemented ever. It existed but it did nothing. We will resolve this in the next release.
