Date/Time: Sun, 04 Oct 2026 01:55:42 +0000
How to Access London Stock Exchange Data
View Count: 2962
| [2020-01-15 03:40:17] |
The London stock exchange recently began to charge a fee for accessing even End of Day historical data. The suffix use with London stock exchange symbols for the Sierra Chart Historical Data service has also been changed from .LS to LN. All of the necessary implementation is now completed on our side in regards to the above. To access London stock exchange data, whether it is historical data or delayed streaming data, requires that you use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Instructions are on the page linked above. And activate the London stock exchange fee for 5.25 USD per month. This will give you historical chart data both historical daily and historical Intraday data and delayed streaming Intraday data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-09-06 18:29:13] |
| MONEIGHT CAPITAL - Posts: 7 |
Hello, I just bought LSE Data and it only goes to 06/2013, not further (for historical chart). Is further data available?
| [2020-09-07 22:05:20] |
If there is not data further back in time for a Historical Daily chart, then that must be all that is available. Here is the relevant documentation for this: No Historical Chart or Blank Chart | Historical Chart Not Updating | Missing Historical Chart Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-07 22:05:25
