Date/Time: Sun, 19 May 2024 20:00:11 +0000
Market Depth data for ICE US futures not shown on DOM.
View Count: 1224
[2020-01-14 11:33:25] |
Schneitzer - Posts: 8 |
Hello, I'm using a CQG data-feed and I just activated ICE US futures with them. However, I wasn't able to see market depth data for ICE US futures, while the market depth data for other exchanges work properly. I've attached a picture of the DOM of the Sugar futures and the DOM of the 30yr US treasury futures for comparison. I would like to know what symbol settings I should look for to correctly display the market depth data. Thank you! http://www.sierrachart.com/image.php?Image=1579001274970.png http://www.sierrachart.com/image.php?Image=1579001333161.png |
[2020-01-14 18:28:53] |
Check this setting: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) But if it is 0, then CQG is not providing any depth data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
