Date/Time: Mon, 25 Nov 2024 01:54:27 +0000
6E Volume By Price with Continuous Volume Based Back Adjusted Issue
View Count: 1296
[2014-01-02 14:59:25] |
drw112 - Posts: 24 |
When I load up 6E with Continuous volume based back adjusted using the SC data feed it loads fine. As soon as I add a Volume By Price study I get the output as shown in the screenshot. I tried this on 1068 and 1069. http://www.sierrachart.com/image.php?l=1388674587906.png |
[2014-01-02 16:52:04] |
We are checking on this now.
[2014-01-02 17:05:38] |
We have done several tests. Looks good for us. Here is an image: http://www.sierrachart.com/image.php?l=1388682203818.png We recommend re-downloading the data by selecting Edit >> Delete All Data and Download. At the prompt press No to download data for all symbols. If you still have difficulty we will need to get a Chartbook containing a single chart with the Volume by Price study configuration you are using, so we can test. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-02 22:55:27
