Date/Time: Thu, 17 Sep 2026 23:37:57 +0000
Recompile code after change in functions
View Count: 1302
[2020-01-14 04:59:50]
User255315 - Posts: 133
Hi SC,
I played around with the sc.OpenFile and sc.ReadFile functions however i get the following error message: FileHandler needs to be recompiled for this version of Sierra Chart. | 2020-01-14 04:50:57.281 *
FileHandler needs to be recompiled for this version of Sierra Chart. | 2020-01-14 04:50:57.789 * (FileHandler is the name of the file)
This error message is persisting even after I have used the int types for function parameters as mentioned in your Update Notes for version 2017.
Could you please look into what is wrong here? Or if possible, update an example code for the new sc.OpenFile function?
[2020-01-14 08:20:55]
That error message, means that you do have to recompile the study. It means it has not been recompiled. Make sure you are using the DLL with Sierra Chart that has actually been rebuilt for the current version. And you are using an up-to-date SierraChart.h file.
All of this will be automatic when using the Remote Build functionality.
Date Time Of Last Edit: 2020-01-14 08:21:12
[2020-01-14 10:04:44]
I am using Sierra version 2028, 64-bit and the dll compiled using VS2015 64-bit. All my other studies have successfully ported using the aforementioned configuration.
The file handling is working only with the remote build option as of now. What might be the problem here?
[2020-01-14 19:01:46]
We think the problem is that you are not using the latest SierraChart.h header file or you are not actually using the recompiled DLL.
[2020-01-15 06:58:28]
how do i download the latest sierra.h file
[2020-01-15 07:02:46]
Nevermind, i figured it out. Thanks a lot!
