Date/Time: Sat, 19 Sep 2026 20:59:58 +0000
Tweek speed performance
View Count: 796
| [2020-01-13 22:13:37] |
| Yeager - Posts: 136 |
Hi, I have a 32gb ram, 2x500 SSD Samsung with high powered graphics card. The processing of the DOM realtime has slowed quite a bit bnut Im pretty suire the machine is capable of running the domes faster. I do use tick date and have optimised my chart intervals on mst of my longer timeframe charts. I was hoping to book a paid session where you mightt be able to pin point where the system is slowing? When I get the sluggish DOMs, the CPU is running only around 45-65%. I have to open a new instance with only DOMS in it if I want realtime fast DOMS. Can we spend some time on this? Thanks Tim |
| [2020-01-13 22:50:56] |
You just need to go through a process of elimination by removing studies and closing charts and see where the problem is.
