Date/Time: Sun, 19 May 2024 11:41:18 +0000
forex/cfd data
View Count: 470
[2020-01-13 21:06:52] |
User311344 - Posts: 136 |
Is there any way to get forex/cfd data using pcg3 from AMP?
[2020-01-13 22:04:55] |
No. Direct Sierra Chart Account When you are using Sierra Chart that has been provided through an affiliate, you do not have a direct paid account with us, and you wish to access functionality that is not provided in your limited version, you must have an account with Sierra Chart directly and have a standard installation of Sierra Chart. To accomplish this, follow the instructions below: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
