Date/Time: Tue, 04 Feb 2025 06:44:54 +0000
Time on chart
View Count: 603
[2020-01-13 20:02:32] |
Bubba - Posts: 30 |
Hello I have my time zone set to Pacific time zone, problem is the chart time 0920a and the actual time 1200p? Not sure what I don't have marked correctly but time isn't changing on chart. Hope you can help Thanks Mark |
[2020-01-13 22:18:45] |
Refer to help topic 38: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-13 22:19:03
