Date/Time: Thu, 25 Apr 2024 10:52:35 +0000
Dumb question
View Count: 881
[2020-01-13 15:40:27] |
User353132 - Posts: 11 |
How do i activate the charts ? They download historicly, but then they don't do anything after that.
[2020-01-13 15:59:51] |
Sierra Chart - Max - Posts: 5596 |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. Sierra Chart Support |
[2020-01-13 17:37:14] |
What futures trading/brokerage service do you use? For the reason why we ask this question, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-13 19:48:40] |
I have Amp with your pkg #5 for data. Using charts transferred from tradepro academy. I work full time during the day, so I'm trying to learn how to use them at night with futures.
[2020-01-13 22:19:19] |
So do you have a funded account with AMP? If not, Follow through the instructions on this page: Easy Solution to CME Funded Trading Account Requirement You only need to pay $100. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-13 22:19:25
[2020-01-16 17:09:24] |
Yes,i said i have amp with the denali data feed.with sierra pkg 5. The cme deducts $25/mo from my amp acct. The only chart i get thats active is a correlation chart. How do i activate t by the rest of the charts ? Roy |
[2020-01-16 17:22:54] |
There is nothing to activate. First thing we want you to do is to update to the current version of Sierra Chart: Software Download: Fast Update Tell us the symbol of what you want to chart. For example did you want to chart the S&P 500 March futures contract? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-22 16:09:34] |
Ok, i did update to the current version and it worked for 2 days. Now, the s&p500 mini isn't active. No "M" besides the F.US.EPH20. What can i do now ? |
[2020-01-22 16:15:23] |
[2020-01-22 16:50:17] |
Sierra_Chart Engineering - Posts: 14076 |
We show that you are not running the current version of Sierra Chart. Update following these instructions: Software Download: Fast Update Let us know when done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-22 20:27:43] |
Hello, I ran the fast update again, said that I already have the current version.
[2020-01-22 21:00:04] |
Hello we called and left a message. Let us know when we can call and use remote assistance to look into this. Thank you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-23 01:35:32] |
Hello, I got your message. I'm home now. Are you still available ?
[2020-01-23 02:19:28] |
Yes, we are calling now.
[2020-01-23 02:34:10] |
User called and issue resolved. They were using an AMP account which did not have the Denali Data Feed. We recommend activating the Denali Data Feed next month and using that account with Sierra Chart.
