Date/Time: Sat, 26 Sep 2026 12:27:33 +0000
Replay for Sierra 64Bits (Charts Frozen and different timeline)
View Count: 903
| [2020-01-13 14:16:37] |
| User758458 - Posts: 4 |
Hello, I started using the 64bits version since January. But when I want to do a replay like for the V32. This is being a Bug, some DOM and charts do not go into replay, others displays the replay but its frozen or on another timeline. How to get to replay on sierra 64 bits like the previous Sierra 32?? Thanks in advance for your help |
| Attachment Deleted. |
| [2020-01-13 22:53:31] |
| John - SC Support - Posts: 48028 |
Refer to these instructions for replaying a Trading DOM: Replaying Charts: Replaying Trade DOM Windows For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-01-14 09:41:14] |
Hello, The replay function is now operational. Sierra 64 is by default in Symbol ("Record Market Depth Data") in No. Since I switched to Yes, it works like on 32 Bits. Thank you for your help and the speed of your response. Best Regards |
