Date/Time: Sun, 19 May 2024 10:31:44 +0000
CUSTOM CHART MILLISECOND HISOTRY and MIT orders in new release?
View Count: 509
[2020-01-13 05:13:05] |
User450179 - Posts: 105 |
HI, I know you gusy are very busy but i had a question a broad one. I am not looking for an exact date. maybe just a month window or so as an estimate of course. For the custom symbosl when do you think you would have historical microsecond data avaialble? for the MIT orders that were shut off when do you think you might have that functionality turned back on with GAIN? thank you |
[2020-01-13 05:36:52] |
Historical data support for custom symbols has been completed. We just need to do final testing and code review. For Market if Touched orders for Gain Capital, just update to the latest prerelease. This was done at least two weeks ago. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-13 19:20:51] |
Keep up the great work and very excited to hear when we can start tradign direct with your new connection. thanks again for everything.
