Date/Time: Tue, 04 Feb 2025 07:03:25 +0000
Black space between Scale of the chart and edge of chart
View Count: 832
[2020-01-12 18:55:02]
User800328 - Posts: 50
Can you please tell me how I can get rid of the black space between the scale and the right side edge of the charts. (The RED RECTANGLE I have drawn on the charts.)
I am seeing this problem mostly in TICK charts such as 3600Tick etc. But some times I don't see this. I used these charts for ever and never had this problem but seeing this problem just recently.
This is NOT the Lock Fill space, I have tried all possibilities with the Lock Fill space and not to any use.
Please see the attached pic.
Thanks.
imageimage.png / V - Attached On 2020-01-12 18:54:42 UTC - Size: 442.7 KB - 289 views
[2020-01-12 22:16:42]
Make sure these two options are disabled:
Trade Menu: Trading Chart DOM On (Trade menu)
Trade Menu: Show Market Data Columns (Trade menu)
And if the extra space is still not removed, then select Chart >> Reload Chart.
Date Time Of Last Edit: 2020-01-12 22:17:20
[2020-01-13 02:34:03]
Thank-you It really helped.
Can I ask you another question. For the last 2 days, my charts have become really slow. In fact, my earlier chartbooks fails to load and it gets stuck at "Calculating Studies" and "Downloading data".... I have to recreate the whole chartbook again but then it again takes ages to load.
Everything was fine on Friday but last 2 days, its been so much pain.
What should I do. ?
[2020-01-14 00:33:16]
Refer to this page:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
Date Time Of Last Edit: 2020-01-14 00:33:39
[2020-01-14 03:12:01]
Thank you.
[2020-01-14 03:13:12]
You can close the ticket. I will look into it making the charts faster as per the article you shared.
Thanks.
